Discussion topic: My sky q mini box isn’t working. It says there are issues with the activation server? Error Mr106
Message posted on 15 Jun 2023 11:05 AM
The message on the screen is that my sky mini box hasn't been able to connect to the activation centre
Message posted on 15 Jun 2023 11:14 AM
Re: My sky q mini box isn’t working. It says there are issues with the activation server? Error Mr1
Hi @KateMog
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
Message posted on 15 Jun 2023 10:26 PM
I have same problem and have rebooted, turned on/off many times with no success. Person who googled and solved problem in another thread can you tell us what worked please?
Message posted on 12 Jan 2024 08:09 AM
I've just had the same issue with mini sky q & after trying to reboot several times I just took the viewing card out & replaced it & it was working immediately
Message posted on 07 Feb 2024 06:42 PM
Thank you Gill 65 - I followed your example and it worked perfectly
Steve H
Message posted on 20 Apr 2024 12:02 AM
Thanks @Gill65 this worked instantly for me too after several unsuccessful resets.
