This discussion topic has been answered Discussion topic: My sky q mini box constantly keeps losing connection to the main sky q box
Message posted on 06 Nov 2023 10:53 PM
Re: My sky q mini box constantly keeps losing connection to the main sky q box
i had problems like this found out it was on eco mode in the settings turn it off on both boxes also when the sky q updates box u need to put sky q on stand by and switch on it will be updated then u will need to re connect mini box as the update on sky q knocks the mini out !! hope this helps !! good luck !!
Message posted on 08 Nov 2023 01:58 PM
Thanks all, I will try your suggestions and if no luck try another call with Sky. Almost reassuring to see it's not just us experiencing the issue, it drives me mad!
Message posted on 18 Dec 2023 02:16 PM
Hi,
We have 3 min boxes and Sky Q, we keep losing connectivity to the Sky Q box from all 3 mini's mostly at differing times but occasionly all together. The Sky Q box continues to work fine.
We have always kept restarting the boxes, but this does not prevent it happening agai. We are seeing this issue daily and it seems to be increasing in regularity.
From this community chat it would seem we need to replace at minimum the 3 miniboxes and possibly the main Sky Q box.
Any further help?
Message posted on 18 Dec 2023 04:08 PM
@Leet5096 wrote:
Hi,
Any further help?
@Leet5096 you say you are restarting them are you only restarting the mini boxes ? if so try
rebooting your main Q box ie
then rebooting each mini box
Message posted on 18 Dec 2023 04:41 PM
@Laing1 I have rebooted all Sky boxes and still no improvement. I have now booked a Sky engineer to visit
