Discussion topic: My sky q box will not connect to my router. I’ve tried it several times with no success
Message posted on 02 Jan 2024 02:03 PM
Message posted on 02 Jan 2024 02:14 PM
Re: My sky q box will not connect to my router. I’ve tried it several times with no success
Hi @DH8497
Are you carrying out a Network reset exactly as follows:-
Message posted on 02 Jan 2024 03:40 PM
@oldfella @Thank you for your reply. I've spoke to sky. I needed to press the router WPS button for 5 sec then press the WPS button on the box for 5 seconds. I'm all connected now.
I done the above after switching of the box and router at the mains for 2 min
