Discussion topic: My sky q box says no satellite signal. No apparent problems with the dish
This message was authored by: Gsdcrazylass
All was fine, got a bar across the bottom of the screen, turned it off and on again at the wall and now nothjng
Re: My sky q box says no satellite signal. No apparent problems with the dish
@Gsdcrazylass
If it displays no satellite signal take a look at the troubleshooting here
It may then give you the opportunity to arrange an engineer to check the alignment of your dish. If you’re on a communal dish system in the UK you’ll have to contact your landlord or building management company rather than Sky.
Hi @Gsdcrazylass
If you can get into the Q box menu!111
This message was authored by: Jan67
I took have lost signal about 7.30pm no sat signal , very annoying,this happened last month as well ,The sat signal came back next morning.
@Jan67
The dish might need re-alignment especially if you'd had the strong winds from the recent storms.
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
This message was authored by: SKYQwSKYfiber
my Sky Q box is starting to show this error almost daily now, if I unplug for a few seconds and turn back on the signal is back 100% so defo not a dish issue, Qbox is +7 years old now so maybe its just at the end of its life ? Have tried software update too but no fix
@SKYQwSKYfiber
More likely a dish issue so complete the troubleshooting in my earlier post.
This message was authored by: FredMel
Bit late to this discussion but we had a similar problem on our Sky Q box. We are on a communal dish and it eventually transpired that, following a software/firmware update, the LNB setting had defaulted to 'Wideband'. This is the setting for an individual satellite dish, not a communal one. For communal dishes it essential to change the box to 'SCR', then reset, all done via the engineers menu. This cured the problem.
