Discussion topic: My sky q box says it has no internet connection right now. This has been going on for weeks.
Message posted on 19 Mar 2025 11:37 AM
For the last 3 weeks our sky q box has said it isn't connected to the internet. We can't get any services like catch up tv etc. every other device in our home is connected and there is not a problem with our broadband. we have done every type of reset numerous times. Today it said we are trying hard to fix this problem. Now I look again and it says there is no connection. The phone number you are told to ring has been impossible to use to solve our issue. Can anyone help? TIA
Message posted on 19 Mar 2025 11:40 AM
Re: My sky q box says it has no internet connection right now. This has been going on for weeks.
Hi @_Pipmcg-
Assume you have carried out the following:-
Message posted on 19 Mar 2025 04:03 PM
hi, did you maage to get it sorted ?? mines exactly the same
Message posted on 20 Mar 2025 10:09 PM
No. Tested everything all over again and nothing. All we need is to actually talk to Sky but it appears impossible! We are at a loss.
Message posted on 21 Mar 2025 05:37 PM
@_Pipmcg- I have escalated this to sky
You may receive an email or a private message inviting you to have a private conversation on the Community with a Sky Expert.
Look out for a chat bubble at the bottom of your screen inviting you to a chat
If you are using the Safari browser please make sure that Hide IP Address is not checked in order to see the chat bubble. If you are having trouble finding this to check the settings, use another browser such as Firefox, Chrome etc.
The link below explains how the escalation process works
Message posted on 22 Mar 2025 09:05 AM
Hi there! Thank you for escalating this. We have sent an invite to @_Pipmcg-.
Message posted on 31 Mar 2025 01:04 PM
Sky says we have to prove that we have internet connection and that it service provider has done nothing. They won't send an engineer out to see us without this proof!
Message posted on 07 Jul 2025 03:19 PM
What if it's connected to the hub by Ethernet? I don't understand how the connection suddenly stops existing. It connects and disconnects at will. It's driving me nuts!
Message posted on 07 Jul 2025 04:12 PM
Hi having the same type of problem but box shows router connection ok but internet connection goes in and out. Had reset bt router and all phones were working fine. Called sky , they went through the settings and found nothing, so have booked me an engineer visit. This is the second time in a couple of months, last time we just turned the box off and is was ok the next day. It has been used a lot lately, wife tennis fan, so maybe just overheating problem plus it is 7 years old.
