Discussion topic: My sky q box keeps reverting to standby every few minutes
This message was authored by Siskin30045 This message was authored by: Siskin30045
My sky Q box keeps reverting back to standby every few minutes. No one us touching the box or remote at the time. Please help.
Re: My sky q box keeps reverting to standby every few minutes
Hi @Siskin30045
Siskin30045
I've done that...
My netflix and amazon apps have disappeared
@Siskin30045 wrote:
I've done that...
Hi @Siskin30045
Try refreshing the Apps in the Hidden menu.
Select Apps 
then highlight Refresh all Apps on this box.
You'll see a message that says, 'Your apps are being refreshed'. This will stay on screen until you press Dismiss to return to normal viewing
It’s recommended waiting at least 5 minutes before doing so.
Refresh Apps can take up to 24 hrs to complete .
