Discussion topic: My sky q box keeps freezing and won't change channels or apps
Message posted on 11 Sep 2024 08:58 AM
Sky Q box will show a program but when I try to change channels there is no response. Switch off at mains and back on works then a few minutes later it happens again.
Message posted on 11 Sep 2024 09:34 AM
Re: My sky q box keeps freezing and won't change channels or apps
Hi @SKYEC267
