Discussion topic: My sky q box isn’t working
Message posted on 04 Aug 2023 05:01 PM
My sky q box isn't working. When I turn it on it is linked to the tv as the normal text comes up saying that it's loading up etc. After this it says to press the home button but nothing happens when I press it
Message posted on 04 Aug 2023 05:04 PM
Re: My sky q box isn’t working
Try a reboot again.
If you had to press the button on the Q box to turn it on
Try completly resetting your Bluetooth remote (with the Q box up and running)
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
