Discussion topic: My sky q box is saying it’s not connected to my internet and no apps are working
This message was authored by: Jenz241
My sky a box is saying it's not connected to internet and no apps are working my internet is working fine it's the sky tv is the problem
Re: My sky q box is saying it’s not connected to my internet and no apps are working
Hi @Jenz241
