Discussion topic: My sky q box is not working in my bed room
This message was authored by: Ally1984
my sky cube box is not working in my bedroom. It's saying connect to Wi-Fi or connect to ethernet
Re: My sky q box is not working in my bed room
Hi @Ally1984
Reboot the mini as above.
