Discussion topic: My sky q box is hot and saying there is no satellite signal
Message posted on 22 Aug 2024 09:12 PM
The satellite dish looks ok and I have tried un plugging the Sky Q box and re-starting and it is stuck on the yellow stand by display and won't go green.
Message posted on 23 Aug 2024 05:25 AM
Re: My sky q box is hot and saying there is no satellite signal
Regarding the “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
If your Sky Q box is stuck on standby try this link
