5
This discussion topic has been answered Discussion topic: My sky q box has an amber light, it wont turn to green and the tv is not picking it up. Ive changed
This message was authored by: Gill+5
My sky q box only had an Amber light. It won't turn on. I've changed batteries in controller and pressed the buttons on the front but nothing happens
Avatar for Gill+5
This message was authored by: Gill+5 Answer
Re: My sky q box has an amber light, it wont turn to green and the tv is not picking it up. Ive chan
@oldfella thank you for you help, really useful. Had to do a system re-set in the end.
Have you pressed the Amber Standby light on the right hand side @Gill+5 ?
If you have work through the following link.
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Avatar for Gill+5
This message was authored by: hugh2
My main sky box gas an Amber light it won't go green please help me as I have no sky TV at all
 @hugh2 if it won't turn on with the remote have you tried pressing where the amber light is as that is a button as well then we will know if its a problem with the box or the remote
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: sue_rusby_1961
Answered - Go to Answer
