Discussion topic: My sky q box can’t connect to sky router
Message posted on 22 Nov 2025 06:00 PM
Suddenly my sky box lost its internet connection, My WiFi and router seem fine but my sky q box can't connect to it. I've tried pressing the WPS butt to re connect but it doesn't work
Message posted on 22 Nov 2025 07:40 PM
Re: My sky q box can’t connect to sky router
Hi @mik3land
If your router does not have a reset button, reboot it by disconnecting the power lead for 30 secs and then reconnecting.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new white Sky Max router then you need to connect it as if it is a 3rd party router.
With a 3rd router then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
