Discussion topic: My sky not working saying fault
Message posted on 16 Dec 2023 11:06 AM
My sky not working from my second box saying fault
Message posted on 16 Dec 2023 11:26 AM
Re: My sky not working saying fault
Hi @Alliemarie
Reboot the mini as above.
