Discussion topic: My sky minibox is not responding . It is showing the red light and will not switch on by remote or
This message was authored by: PGC05
Message posted on 21 Feb 2024 09:20 AM
I have rebooted several times
Find out more
Message posted on 21 Feb 2024 09:31 AM
Re: My sky minibox is not responding . It is showing the red light and will not switch on by remote
Hi @PGC05
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
Try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
