Discussion topic: My sky mini boxes keep losing connection. I have turned off all other devices that might interfere a
This message was authored by: Rachel72
My mini boxes keep losing connection. Whether it's just watching normal TV or if watching on record. Also if on record when I go to fast forward the breaks it gets stuck and won't stop. It happens all the time now to the point that we give up. I have tried turning off any devices around the house that might cause interference like amazon alexa and I've upgraded my main WiFi and got booster boxes around the house but it is still so bad.
Re: My sky mini boxes keep losing connection. I have turned off all other devices that might interfe
Hi @Rachel72
If you WiFi boosters are not Sky Q boosters then the minis will not connect reliably to them.  They will only connect to Q WiFi.
Reboot the mini as above.
Avatar for Rachel72
Level 0 icon
My WiFi is with EE and they have sent me the boosters so no they are not Sky Q boosters. Will they interfere even more or help. Do Sky provide boosters for mini boxes or do you have to be on sky wifi
Hi @Rachel72
Any 3rd party WiFi or boosters could interfere with the Sky Q WiFi that the minis are trying to connect to.
Sky do supply boosters to aid Q connectivity.
In your scenario you would need one positioned midway between the mini and the nearest connected Q device.   Normally this would be the main Q box but another mini could be used if connected with stong WiFi.
