3
This discussion topic has been answered Discussion topic: My sky mini box stays on red when i try to turn it on, ive tried rebooting the main sky box but it's
This message was authored by: Marzy
My sky mini box stays on red when I try to turn it on. I've tried rebooting the main sky box but it's not working.
Re: My sky mini box stays on red when i try to turn it on, ive tried rebooting the main sky box but
Hi @Marzy
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
Try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
To complete the recovery procedure on your Sky Q Mini box:
  1. Switch the Sky Q Mini box off at the mains.
  2. Hold down the Reset button on the back of the Sky Q Mini box and switch it back on at the mains.
  3. Keep holding it until the light on the front flashes red and green. This will take about 30 seconds.
  4. Once it flashes red and green, press the standby button on the front of the box.
It may need replacement for which you'll need to call Sky.
Hi @Marzy
Avatar for Marzy
Thank you for trying to help me. I had to phone Sky and they helped me to input the remote and it worked.
