Discussion topic: My sky mini box stays amber but main box fine
Message posted on 10 Jan 2024 08:36 PM
My sky mini box not turning on stays amber
Message posted on 10 Jan 2024 08:40 PM
Re: My sky mini box stays amber but main box fine
Hi @Mike121
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
Try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Message posted on 10 Jan 2024 09:03 PM
Hi thanks it has done something but still not working
Message posted on 10 Jan 2024 09:25 PM
Hi @Mike121
Reboot the mini as above.
