Discussion topic: My sky mini box not connecting to main
Message posted on 19 Jun 2024 05:21 PM
My sky mini box is not connecting even thou main one is on
Message posted on 19 Jun 2024 06:21 PM
Re: My sky mini box not connecting to main
Hi @Craig-97
Reboot the mini as above.
