3
This discussion topic has been answered Discussion topic: My sky mini box lost network connection. I’ve reset but the screen is blank
This message was authored by: MDJ1
After resetting my sky mini box I have a blank screen. It's completely blank
Avatar for MDJ1
This message was authored by: MDJ1 Answer
Re: My sky mini box lost network connection. I’ve reset but the screen is blank
It turned out to be the remote had lost connection to the mini and it wouldnt reactivate when the screen went blank. The extenders and the rest of the boxes were fine. Just had to repair the handset. What a performance, but thanks anyway. Apparently it's a common fault 🙄🙄
Hi @MDJ1
Unless you are with Sky broadband your mini if using WiFi can only connect to the main Q box or another mini or a Sky booster.
Reboot the mini as above.
Avatar for MDJ1
This message was authored by: hotpeppers
Why hasn`t the SKY Q box got a proper menu item to reboot it. Going into standby and unplugging is not healthly for the hard drive and other components. I generally have to reboot my SKY Q box at least once every 2 months to reactivate the Sky Minis. Yes. I`ve tried everthing else (reboot router, unplug nework etc) but only thing that cures is the reboot. Or is there something else that can be done on the main box first even though this won`t connect to my network (wired or wirelss). Help.
