Discussion topic: My sky mini box keeps losing connection with main sky Q box. I need a bridge to boost signal
Message posted on 08 Mar 2024 01:30 PM
My Sky mini box keeps losing it's connection with Sky Q box
Message posted on 08 Mar 2024 02:40 PM
Re: My sky mini box keeps losing connection with main sky Q box. I need a bridge to boost signal
@Gary74 Have you tried rebooting your main Q box ie
then reboot the mini box
Message posted on 08 Mar 2024 04:00 PM
Hi @Gary74
Try a Network Reset on the mini.
