Discussion topic: My sky mini box keeps freezing, loses sound and or picture
Message posted on 10 Aug 2024 01:19 PM
Our sky mini box in the kitchen keeps freezing, loses sound and/or picture, has been working fine up until now
Message posted on 10 Aug 2024 01:26 PM
Re: My sky mini box keeps freezing, loses sound and or picture
@Karencoops Have you tried rebooting your main Q box ie
then
rebooting the mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 10 Aug 2024 01:41 PM
Hi thanks yes have tried this but no change
Message posted on 10 Aug 2024 01:46 PM
Hi @Karencoops
Try a Network Reset on the mini.
