Discussion topic: My sky mini box isn’t connecting tryed everything
This message was authored by Abi+chino This message was authored by: Abi+chino
My sky mini box isn't working it's not connecting I've rebooted it and it's not working
Re: My sky mini box isn’t connecting tryed everything
Hi @Abi+chino
Reboot the mini as above.
This message was authored by Norse+1 This message was authored by: Norse+1
Eorror mr001 please send me an engineer
Hi @Norse+1
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
Regarding your mr001 issue
Try the procedure in my earlier post
