Discussion topic: My sky mini box in my bedroom is not working I have went through all the troubleshooting but it is s
This message was authored by: Mark510
My sky mini box is not working. I have tried rebooting the main one and have done all the troubleshooting but it is still not working this has been for two days now
Re: My sky mini box in my bedroom is not working I have went through all the troubleshooting but it
@Mark510
In what way isn't it working? Any error messages on the TV screen?
Avatar for Mark510
It is not connecting to the main q box in the living room I have rebooted everything and still no joy
Hi @Mark510
Try a Network Reset on the mini.
