Discussion topic: My sky keeps freezing up and loosing picture
This message was authored by: Richard741
My sky keeps freezing and then it comes up saying there's a problem with my connection. This is on both the main box and mini box
Re: My sky keeps freezing up and loosing picture
Hi @Richard741
Try reconnecting your Main Q box.
This message was authored by: CarolineFleming
My signal is fine its my sky TV that keeps freezing
My signal is fine its my tv programs  that keeps freezing
