Discussion topic: My sky keeps freezing and glitching. I've tried re setting my sky changing TV's and checking plugs
This message was authored by: Zoe28
My Sky keeps freezing the picture and sound. I've tried re setting sky through the router, and un plugging it all. I've even tried a different TV but had no luck. The TV will work for about 30 seconds at a time in 5 minute intervals. So impossible to watch TV.
Re: My sky keeps freezing and glitching. I've tried re setting my sky changing TV's and checking plu
Hi @Zoe28
