2
This discussion topic has been answered Discussion topic: My sky is saying no signal ,then it works for a minute and then it says no signal again ,then worfor
This message was authored by: Bj66
It keeps switching from no signal to working then no signal to working. It's just going back and forth
Re: My sky is saying no signal ,then it works for a minute and then it says no signal again ,then wo
@Bj66 wrote:
As I've said it keeps switching back and forth from working to no signal
Hi @Bj66
If it says No signal then this is TV set message and not from Sky.   Check that your HDMI lead between the Sky Box and TV is correctly fitted at both ends.  Also worth trying another HDMI lead if you have one.
If it says No Satellite signal then this is from your Sky Box.  There are lots of heavy cloud weather issues over the UK at this time and these could cause an intermittent loss of Signal.   If it happens in clear weather see the following link.
Work through the following link and if you cannot solve your issue it will lead to booking a Engineer.
Avatar for Bj66
Hi @Bj66
