Discussion topic: My sky is not working, keeps saying no satellite signal is being received
Message posted on 10 Jul 2024 03:21 PM
L this channel is currently affected by a problem with your satellite signal" sometimes there is a picture but it it is not watchable as it keeps flashing and breaking up. I have tried turning it off at the wall but it made no difference.
Message posted on 10 Jul 2024 03:25 PM
Re: My sky is not working, keeps saying no satellite signal is being received
@Annabheag
A message displaying “no satellite signal” relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check the troubleshooting in this link
If you are connected to a communal dish you’ll need to liaise with you building management company / landlord who will have their approved engineers to contact.
Note: A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
Message posted on 10 Jul 2024 03:28 PM
Hi @Annabheag As long as it is not bad weather conditions, it sounds like your dish (if you are not on a communial dish) may need re-aligning or at least checked. You should call Sky and book an engineer.
