Discussion topic: My sky is not working but my wifi is , I’ve completed instructions on setting but still not working
This message was authored by Sarahblue74 This message was authored by: Sarahblue74
Skyway not working but WiFi is
Re: My sky is not working but my wifi is , I’ve completed instructions on setting but still not work
@Sarahblue74  I'm afraid your post isn't very clear, what is Skyway?  This isn't something i've heard of being provided by Sky UK.
Samsung 75" 4K TV, Sky Glass, Sky Stream, VM 1 Gig Broadband, Sony 7.1 AV Receiver, Technisat MultiSat receiver.
Sarahblue74
Sorry I meant Sky Q
This message was authored by GillM This message was authored by: GillM
I'm having the same problem. Sky Q not working but Internet is
@Sarahblue74 wrote:
Sorry I meant Sky Q
Hi @Sarahblue74
First try rebooting your Q box.
If your Q box has no internet connection
Sarahblue74
Thank you it's still not working thou I'll have to ring a sky engineer up
