Discussion topic: My sky is not working but my wifi is , I’ve completed instructions on setting but still not working
This message was authored by: Sarahblue74
Skyway not working but WiFi is
Re: My sky is not working but my wifi is , I’ve completed instructions on setting but still not work
@Sarahblue74  I'm afraid your post isn't very clear, what is Skyway?  This isn't something i've heard of being provided by Sky UK.
Samsung 75" 4K TV, Sky Glass Gen 2 55", Sky Stream, VM 1 Gig Broadband, Sony 7.1 AV Receiver, Technisat MultiSat receiver.
Avatar for Sarahblue74
Sorry I meant Sky Q
This message was authored by: GillM
I'm having the same problem. Sky Q not working but Internet is
@Sarahblue74 wrote:
Sorry I meant Sky Q
Hi @Sarahblue74
First try rebooting your Q box.
If your Q box has no internet connection
Thank you it's still not working thou I'll have to ring a sky engineer up
