Discussion topic: My sky is not connecting to the internet
Message posted on 27 Oct 2023 07:55 PM
My sky is not working tonight , says it's not connected to the internet , but my internet is working .
Message posted on 27 Oct 2023 08:28 PM
Re: My sky is not connecting to the internet
Hi @Sian142
Try a Network reset on your main Q box.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
