Discussion topic: My sky dish is knocking on the wall in windy weather
Message posted on 19 Mar 2024 05:26 AM
This dish was installed less than a month ago. Will sky come out and fix it free. Who do I phone.
Message posted on 19 Mar 2024 05:28 AM
Re: My sky dish is knocking on the wall in windy weather
Technically the dish and cables are your responsibility but as it was erected so recently I think Sky would likely re attend to fix this.
You can call Sky free by dialling 150 from a Sky Talk landline or a Sky Mobile, otherwise you can use:
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ and it provides a 0333 number.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ and it provides a 0818 number.
(The forum doesn’t allow us to type the numbers in full).
You will find that similar to calling other large companies the start will be automated which may also try to send you back to the forum. Stay on the line as long as possible and don’t hang up.
NOTE: I only provide help on the forum boards and NOT via Direct Messaging so DMs are switched off
