Discussion topic: My sky box wont turn on using remote . I have replaced the batteries. I have rebooted sky m
Message posted on 01 Apr 2024 06:50 AM
hi I have replaced batteries in remote
My box wont turn on unless I do so manually.
I have rebooted Internet etc
And all tv
I can use the remote to do other things however not with sky q
Message posted on 01 Apr 2024 08:28 AM - last edited: 01 Apr 2024 08:30 AM
Re: My sky box wont turn on using remote . I have replaced the batteries. I have rebooted sky m
And all tv
Hi @LATT Make sure you are using your SKYQ remote and not your TV remote first?
Try completly resetting your Bluetooth remote. Press and hold 7 & 9 together on the remote until it's led flashes four times. Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair?
