Discussion topic: My sky box won’t connect to internet. No problem yesterday. It will not accept my password
Message posted on 10 Aug 2024 09:13 PM
I've restarted the box twice. I have WiFi on all other devices in my home
Message posted on 10 Aug 2024 09:17 PM
Re: My sky box won’t connect to internet. No problem yesterday. It will not accept my password
Hi @Maxina
Message posted on 10 Aug 2024 09:42 PM
Rebooted the router and the sky box still will not connect. What next?
Message posted on 10 Aug 2024 09:53 PM
