Discussion topic: My sky box will not connect to my sky router
Message posted on 01 Jan 2024 06:15 PM
My sky box won't connect to my sky router
Message posted on 01 Jan 2024 06:20 PM - last edited: 01 Jan 2024 06:21 PM
Re: My sky box will not connect to my sky router
Hi @John281
Assume you have carried out a Network reset on the Q box exactly as follows;
As you are on Sky broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
