Discussion topic: My sky box will not connect to my broadband
This message was authored by Chris3356 This message was authored by: Chris3356
My internet went down for two days. I eventually got it up and running but my sky tv box will not connect to the internet
Re: My sky box will not connect to my broadband
Hi @Chris3356
Try a Network Reset found in Q box Home - Settings - Setup - Network.
