Discussion topic: My sky box tries to connect to another broadband network not mine
Message posted on 03 Feb 2025 05:31 PM
My sky box regularly loses connection and then tries unsuccessfully to connect to a neighbouring broadband network not mine. Any ideas ?
Message posted on 03 Feb 2025 08:30 PM
Re: My sky box tries to connect to another broadband network not mine
How do you know it's trying to do that?
Message posted on 03 Feb 2025 08:34 PM
When I notice sky is not working and lost connection under settings it shows the rogue network name it is trying to connect to.
Message posted on 03 Feb 2025 09:20 PM
Nah, that's just its internal wifi mesh name
Message posted on 03 Feb 2025 09:34 PM
Thanks - Do you know, if I connect the skyq box via an ethernet cable will that solve the problem and I can still connect my sky mini boxes via wifi ?
Message posted on 03 Feb 2025 09:53 PM
It might work if you disable 2.4GHz wifi (which the Q uses to connect to non-original-Sky-routers) and leave 5GHz enabled (which is what it uses to talk to the mini)
or use powerlines to connect the mini and disable wifi completely.
