11
This discussion topic has been answered Discussion topic: My sky box keeps cutting out to a black screen. Its only temporary (a second or less)
This message was authored by: ChrisJ1961
Keeps going to a black screen every minute or so. I thought at first it was an atmospheric problem, as it was throwing it down with rain, but that appears not to be the case. It happens on a regular basis, only for a second or so, but its annoying when I'm watching a film or live sports. Anyone else having this problem after having a Q box installed recently ?
This message was authored by: PandJ2020 Answer
Re: My sky box keeps cutting out to a black screen. Its only temporary (a second or less)
Are you using the HDMI lead supplied by Sky?
@ChrisJ1961 have you tried changing your HDMI cable
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for ChrisJ1961
Yes mate I am
@ChrisJ1961 wrote:
Yes mate I am
@ChrisJ1961 so have you tried a different HDMI lead  ? as obviously you are having the problem whilst using the one supplied by Sky
This message was authored by: Skyqme
Hello
Mine has been doing this for weeks now , new sky q box , software updated , expensive hdmi lead ( tried in every port ) my ps5 and fire stick work fine in the same ports ( unplugged/ disconnected when fault finding) , tv and sky q are in separate sockets (plugs) it's unwatchable , signal is 90 and 90 . Every electrical outlet in the room is empty and off . Even the other rooms . Apps and channels are equally effected. Black screen flashes / blips happen frequently some times we get 20min before it happens other times it everywhere min. Internet is solid too can wfh stream and game with no visible issues
Anyone resolved this . ?
This message was authored by: loanz
Mine is doing the exact same thing,  I also have the sky mini box which isn't doing it. So.... I've tried useing the hdmi from the mini, still does it, I've tried useing my 4k hdmi from the ps5, still does it. I've tried resetting my sky box back to factory settings, still does it, I've tried resorting my TV back to factory settings, still does it. It doesn't happen with ps5 or the Nintendo switch, just the sky box a couple of months ago ( its actually my 2nd one as the first one they sent was faulty), my old box lasted 7 years without a single issue, currently the euros are on,.if I miss a goal I'm going to pretty annoyed, the box is out in the open, well ventalated, no physical damage to any leads, checked the plug socket its in, no faults visible. I've also went to extreme, I've opened my TV, checked my t-con board, checked my y-con board ( these 2 separately control the sound a picture ) checked my power board, checked every capacitor, checked every fuse, checked every chip, found no issues. Also, the TV settings page remains on the screen when the sky box cuts out, it's not the sky box turning off and on as it lasts half a second then resumes with what it was doing, its very annoying, clearly the latest sky box is not fit for purpose, and considering the price you pay to watch sky, you would expect a lot better. For now I'll have to connect my sky mini and have my main sky box on next to it. Not an ideal solution especially for people who don't have a mini box
This message was authored by: hardy74
Yes iam having the same problem , sky told me it was a compatibility issue with the Toshiba I had , just replaced it with a 2024 Hisense , last night was fine , this morning ok , then my wife just rung and said it was back doing it again , so god knows what the issue is
I thought it may have been an issue with the dish, but having changed it, I still have the same problem. Sometimes it doesn't cut out at all, and then it does.
I've tried changing the tv's around too. Main is a 55" sharp, then I've tried the LG42 but its still happening.
I can live with it, but it's annoying especially during live sport.
This message was authored by: AndrueCope
Mine's being doing it occasionally for over a year now. Thankfully it doesn't do it during playback but every now and again when exiting playback I get a black screen instead of the main menu. I've also had a 'no signal' message from my TV several times when first bringing the box out of standby.
I've been living with it for a while it's a very occasional thing and not worth the hassle of having my box swapped out.
This message was authored by: Qlesssky
Anyone got an answer to this issue?
This message was authored by: Glynry22
Mine is doing this too.  Checked Sky app, it says everything working ok, no issues.   Does anyone have an answer?
