Discussion topic: My sky box is showing the message “technical fault”
This message was authored by: Jodeshea
Message posted on 08 Apr 2023 06:10 PM
Find out more
Message posted on 08 Apr 2023 06:18 PM - last edited: 08 Apr 2023 06:47 PM
Re: My sky box is showing the message “technical fault”
Is this on all channels? What have you tried so far? By the way multiple posts aren't necessary so the others have been removed.
See if this link helps
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
