Discussion topic: My sky box is not coming on
Message posted on ‎24 May 2024 09:46 AM
My sky box has no power not coming on
Message posted on ‎24 May 2024 10:08 AM - last edited: ‎24 May 2024 10:09 AM
Re: My sky box is not coming on
Hi @Hur
What colour is the led on the front right of the Q box?
If it is Amber have you tried switching it on by pressing this led which is the Standby button.
If this turns the box on
