Discussion topic: My sky box is not coming on my Yvonne is but showing no signal I it’s not the r’cont & all s connect
This message was authored by: Bi_c1
Message posted on 17 Nov 2023 04:18 PM
- My sky box isn't coming on my tv is and displaying no signal it isn't the remote control as it still isn't coming on when pressing the on off button directly on the box and everything is connected
Find out more
Message posted on 17 Nov 2023 04:27 PM
Re: My sky box is not coming on my Yvonne is but showing no signal I it’s not the r’cont & all s
@Bi_c1
”No signal” tends to be a message from your TV (in which case check the cables going to the TV). A “no satellite signal” message relates to your Sky box.
If it displays no satellite signal take a look at the troubleshooting here
It may then give you the opportunity to arrange an engineer to check the alignment of your dish. If you’re on a communal dish system in the UK you’ll have to contact your landlord or building management company rather than Sky.
