This discussion topic has been answered Discussion topic: My sky box is apparently not connecting to the internet as though the signal was down. However the.
Message posted on 24 Oct 2023 12:46 PM
My box is not connecting to the internet despite the internet working fine on other devices.
Message posted on 24 Oct 2023 02:21 PM
Thanks. Being inpatient I phoned Sky and was put through to an engineer who solved my problem.
Message posted on 24 Oct 2023 12:56 PM
Re: My sky box is apparently not connecting to the internet as though the signal was down. However
Hi @John953
I assume this is your Main Q box.
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
