Discussion topic: My sky box in bedroom isn’t working
Message posted on 06 May 2024 04:18 PM
Hello my sky box in my bedroom isn't working
Message posted on 06 May 2024 04:28 PM
Re: My sky box in bedroom isn’t working
@2Swallow For the forum to help you'll need to provide a bit more detail.
Message posted on 06 May 2024 04:30 PM
Is it the main box or mini? In what way isn't it working? Any error messages? Has it been working up until now?
Message posted on 06 May 2024 04:38 PM
Hi @2Swallow
Reboot the mini as above.
