4
This discussion topic has been answered Discussion topic: My sky box has no Home Screen and no recordings
This message was authored by: Soph7
My sky box has lost the Home Screen and I can't access the recordings. It seems to be picking up channels still.
Re: My sky box has no Home Screen and no recordings
@Soph7 wrote:
That didn't work unfortunately- the message stated that we need to insert the viewing card, which is inserted
Hi @Soph7
First check that your viewing card is correctly inserted.   Viewing card is in the right hand end of the box.
If it is in correctly there is not enough of it sticking out to grip and remove it.
Push it fully in and it will pop out slightly enough so you can remove it.
Make sure that it is in chip side up and chip end in first.   Push it gently fully in and you should feel a slight click when it is engaged.   If it has popped out enough to remove it is not located correctly.
If you are satisfied that it is in correctly
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
Hi @Soph7
Try rebooting your Q box
Avatar for Soph7
Level 0 icon
Hi @Soph7
Avatar for Soph7
Level 0 icon
Thanks so much, that worked!
