Discussion topic: My sky Q won't switch on with via Home. I need to do it manually and when it turns on it's frozen
This message was authored by: Marie47
Message posted on 30 Jul 2024 04:56 PM
Hi my SKY Q is frozen. I'm getting nowhere with the help option
Find out more
Message posted on 30 Jul 2024 05:05 PM
Re: My sky Q won't switch on with via Home. I need to do it manually and when it turns on it's froze
Hi @Marie47
