Discussion topic: My sky Q mini box won't connect to my main sky box for some unknown reason, everything is connected
Message posted on 30 Aug 2024 04:49 PM
Good Afternoon , i've been trying to connect my Sky Q Mini box that i have in my bedroom , tried connecting it to the main Sky Q box , ( i've had this box quite a while ), i've tried different things and nothing works.
Message posted on 30 Aug 2024 04:59 PM
Re: My sky Q mini box won't connect to my main sky box for some unknown reason, everything is connec
Hi @Jayk72
Reboot the mini as above.
