Discussion topic: My sky Q mini box has stopped working & error mr204 has come up
Message posted on 16 Apr 2023 04:01 PM
My sky q box has stopped working & error mr204 is showing. It has been working perfectly for 18 mo this & hasn't been moved. All other devices are working on the internet
Message posted on 16 Apr 2023 09:43 PM
Re: My sky Q mini box has stopped working & error mr204 has come up
I have exactly the same issue as the above person.
Message posted on 16 Apr 2023 09:50 PM
Hi @Davidush
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
Message posted on 16 Apr 2023 10:47 PM
Thanks my mini box is functioning again however the controls sometimes function and then just stop. Batteries have been changed but I can't select anything. My main box is working but I can't alter the sound. Seems like some kind of gremlin - or software update gone. Wrong?
Message posted on 10 Oct 2023 11:05 PM
The been working but when sky Q box goes off the sky box stopped they is error on it MR204 comes up on my tv with sky mini Q box
Message posted on 11 Oct 2023 06:20 AM
What do you mean by "goes off"? The Q has to be powered up (but can be on standby) for any mini to work.
Message posted on 20 Dec 2023 06:37 PM
This keeps happening to me. I have to turn the box off daily and then it works. Nothing has changed.
Faulty Q box? I have had it since Q started.
Message posted on 20 Mar 2024 10:24 PM
I have basically given up- I've tried rebooting and loads of every other suggestion to no avail. Makes me want to just cancel my subscription- this is a daily problem
