Discussion topic: My sky Q box upstairs is not working AGAIN
Message posted on 25 Nov 2023 07:04 PM
Message posted on 25 Nov 2023 08:11 PM
Re: My sky Q box upstairs is not working AGAIN
@DyApp wrote:
Can you fix it or take the mini box back please.
You're not talking to Sky here - just other customers.
Message posted on 25 Nov 2023 09:22 PM
@DyApp wrote:
My sky Q box upstairs is not working AGAIN. And no the main sky Q box is on its own with nothing by it. I've turned everything off and on again and pressed the reset button on everything, can you fix it or take the mini box back please.
Hi @DyApp
Reboot the mini as above.
Message posted on 10 Nov 2025 08:50 PM
Turned it on and off blue picture up with settings on it but remote controls not letting me move from settings
Message posted on 10 Nov 2025 08:51 PM
Need enigneer 2 sort this out
Message posted on 10 Nov 2025 08:57 PM
hi @GISMO95
May I suggest you try a reset of your remote:
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Now try to access the box - make sure it has line of sight of the box as until it is paired it uses Infrared
If you can now control it, press 1 & 3 together to go through to re-pair with the box and your TV -
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
