8
This discussion topic has been answered Discussion topic: My sky Q box has a green light but we cannot get the tv guide up on the tv it’s just showing sky adv
This message was authored by: Katie1965
We cannot get any programmes on the tv
Re: My sky Q box has a green light but we cannot get the tv guide up on the tv it’s just showing sky
Hi @Katie1965
Have you tried rebooting your Q box?
If you had to press the Standby button on the front of the Q box to switch it on
then
Hi @Katie1965
then
Avatar for Katie1965
Level 0 icon
We cant watch any tv programmes even though the green light is on the sky Q box is on
Level 0 icon
Hi yes we hsve done all that put still no programmes
Have you reset your Qbox remote @Katie1965
Level 0 icon
Amazing thank you it has worked
This message was authored by: SheenaStammers
What a load of crap
If my Sky Q box is not fixed very soon
HELLO VIRGIN
@SheenaStammers wrote:
What a load of crap
HELLO VIRGIN
@SheenaStammers Afraid you are not contacting Sky's customer services on here, this is a customer to customer forum where customers help each other.
If you can describe what problems you are having we may be able to help
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Sorry for that I will try to get in touch with Sky
Do you have a number?
