10 Nov 2023 09:31 PM
Can anyone help me please as my Sky Q box keeps loosing connection with my Sky mini box and I have to keep resetting the router to get connection again. This can happen 2/3 times a night. Thankyou
10 Nov 2023 10:26 PM
Hi @Linz2
Reboot the mini as above.
12 Apr 2024 08:49 PM
After getting rid of sky broadband, my broadband is amazing but the q boxes keep disconnecting. I believe this is a software issue. As I don't lose broadband on any other devices around the house
12 Apr 2024 08:58 PM - last edited: 12 Apr 2024 09:01 PM
The sky boxes connect to each other in their own unique way. Do you have any method of connecting boxes by ethernet cable? Potentially using something like powerline devices if that's something you are familiar with.
Once you are using a non sky broadband, the router doesn't play a huge role in the boxes connecting to each other (while using WiFi at least).
